Adaptive Filtering Techniques Combined with Natural Selection-Based Heuristic Algorithms in the Prediction of Protein-Protein Interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christos M. Dimitrakopoulos
  • Fonction : Auteur
  • PersonId : 992357
Konstantinos A. Theofilatos
  • Fonction : Auteur
  • PersonId : 992359
Spyridon D. Likothanassis
  • Fonction : Auteur
  • PersonId : 992360
Athanasios K. Tsakalidis
  • Fonction : Auteur
  • PersonId : 992342
Seferina P. Mavroudi
  • Fonction : Auteur
  • PersonId : 992361
The analysis of protein-protein interactions (PPIs) is crucial to the understanding of cellular organizations, processes and functions. The reliability of the current experimental approaches interaction data is prone to error. Thus, a variety of computational methods have been developed to supplement the interactions that have been detected experimentally. The present paper’s main objective is to present a novel classification framework for predicting PPIs combining the advantages of two algorithmic methods’ categories (heuristic methods, adaptive filtering techniques) in order to produce high performance classifiers while maintaining their interpretability. Our goal is to find a simple mathematical equation that governs the best classifier enabling the extraction of biological knowledge. State-of-the-art adaptive filtering techniques were combined with the most contemporary heuristic methods which are based in the natural selection process. To the best of our knowledge, this is the first time that the proposed classification framework is applied and analyzed extensively for the problem of predicting PPIs. The proposed methodology was tested with a commonly used data set using all possible combinations of the selected adaptive filtering and heuristic techniques and comparisons were made. The best algorithmic combinations derived from these procedures were Genetic Algorithms with Extended Kalman Filters and Particle Swarm Optimization with Extended Kalman Filters. Using these algorithmic combinations high accuracy interpretable classifiers were produced.
978-3-642-23957-1_52_Chapter.pdf (383.34 Ko) Télécharger le fichier
hal-01571372 , version 1 (02-08-2017)
Paternité
Christos M. Dimitrakopoulos, Konstantinos A. Theofilatos, Efstratios F. Georgopoulos, Spyridon D. Likothanassis, Athanasios K. Tsakalidis, et al.. Adaptive Filtering Techniques Combined with Natural Selection-Based Heuristic Algorithms in the Prediction of Protein-Protein Interactions. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.471-480, ⟨10.1007/978-3-642-23957-1_52⟩. ⟨hal-01571372⟩
49 Consultations
64 Téléchargements
