A New Criterion for Clusters Validation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a new criterion for clusters validation is proposed. This new cluster validation criterion is used to approximate the goodness of a cluster. The clusters which satisfy a threshold of this measure are selected to participate in clustering ensemble. For combining the chosen clusters, a co-association based consensus function is applied. Since the Evidence Accumulation Clustering method cannot derive the co-association matrix from a subset of clusters, a new EAC based method which is called Extended EAC, EEAC, is applied for constructing the co-association matrix from the subset of clusters. Employing this new cluster validation criterion, the obtained ensemble is evaluated on some well-known and standard data sets. The empirical studies show promising results for the ensemble obtained using the proposed criterion comparing with the ensemble obtained using the standard clusters validation criterion.
978-3-642-23960-1_14_Chapter.pdf (94.73 Ko) Télécharger le fichier
hal-01571447 , version 1 (02-08-2017)
Paternité
Hosein Alizadeh, Behrouz Minaei, Hamid Parvin. A New Criterion for Clusters Validation. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.110-115, ⟨10.1007/978-3-642-23960-1_14⟩. ⟨hal-01571447⟩
116 Consultations
101 Téléchargements
