Global Optimization of Analogy-Based Software Cost Estimation with Genetic Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Estimation by Analogy is a popular method in the field of software cost estimation. A number of research approaches focus on optimizing the parameters of the method. This paper proposes an optimal global setup for determining empirically the best method parameter configuration based on genetic algorithms. We describe how such search can be performed, and in particular how spaces whose dimensions are of different type can be explored. We report results on two datasets and compare with approaches that explore partially the search space. Results provide evidence that our method produces similar or better accuracy figures with respect to other approaches.
978-3-642-23960-1_42_Chapter.pdf (114.96 Ko) Télécharger le fichier
hal-01571483 , version 1 (02-08-2017)
Paternité
Dimitrios Milios, Ioannis Stamelos, Christos Chatzibagias. Global Optimization of Analogy-Based Software Cost Estimation with Genetic Algorithms. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.350-359, ⟨10.1007/978-3-642-23960-1_42⟩. ⟨hal-01571483⟩
60 Consultations
78 Téléchargements
