Stacked magnetic resonators for MRI RF coils decoupling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Magnetic Resonance Année : 2017
Elodie Georget
  • Fonction : Auteur
Michel Luong
  • Fonction : Auteur
Alexandre Vignaud
Eric Giacomini
  • Fonction : Auteur
Edouard Chazel
  • Fonction : Auteur
Alexis Amadon
Franck Mauconduit
Stefan Enoch
Gérard Tayeb
Nicolas Bonod
Cyril Poupon
  • Fonction : Auteur
Redha Abdeddaim
  • Fonction : Auteur
Parallel transmission is a very promising method to tackle B 1 + field inhomogeneities at ultrahigh field in magnetic resonant imaging (MRI). This technique is however limited by the mutual coupling between the radiating elements. Here we propose to solve this problem by designing a passive magneto-electric resonator that we here refer to as stacked magnetic resonator (SMR). By combining numerical and experimental methodologies, we prove that this passive solution allows an efficient decoupling of active elements of a phased-array coil. We demonstrate the ability of this technique to significantly reduce by more than 10 dB the coupling preserving the quality of images compared to ideally isolated linear resonators on a spherical salty agar gel phantom in a 7 T MRI scanner.
submission.pdf (618.69 Ko) Télécharger le fichier
hal-01571588 , version 1 (19-07-2018)
Elodie Georget, Michel Luong, Alexandre Vignaud, Eric Giacomini, Edouard Chazel, et al.. Stacked magnetic resonators for MRI RF coils decoupling. Journal of Magnetic Resonance, 2017, 275, pp.11-18. ⟨10.1016/j.jmr.2016.11.012⟩. ⟨hal-01571588⟩
257 Consultations
426 Téléchargements
