Formal Analysis of Security Metrics and Risk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Security metrics are usually defined informally and, therefore, the rigourous analysis of these metrics is a hard task. This analysis is required to identify the existing relations between the security metrics, which try to quantify the same quality: security.Risk, computed as Annualised Loss Expectancy, is often used in order to give the overall assessment of security as a whole. Risk and security metrics are usually defined separately and the relation between these indicators have not been considered thoroughly. In this work we fill this gap by providing a formal definition of risk and formal analysis of relations between security metrics and risk.
978-3-642-21040-2_22_Chapter.pdf (358.38 Ko) Télécharger le fichier
hal-01573302 , version 1 (09-08-2017)
Paternité
Leanid Krautsevich, Fabio Martinelli, Artsiom Yautsiukhin. Formal Analysis of Security Metrics and Risk. 5th Workshop on Information Security Theory and Practices (WISTP), Jun 2011, Heraklion, Crete, Greece. pp.304-319, ⟨10.1007/978-3-642-21040-2_22⟩. ⟨hal-01573302⟩
271 Consultations
75 Téléchargements
