Differential Fault Analysis of the Advanced Encryption Standard Using a Single Fault - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michael Tunstall
  • Fonction : Auteur
  • PersonId : 1011162
Debdeep Mukhopadhyay
  • Fonction : Auteur
  • PersonId : 1014556
Subidh Ali
  • Fonction : Auteur
  • PersonId : 1014557
In this paper we present a differential fault attack that can be applied to the AES using a single fault. We demonstrate that when a single random byte fault is induced at the input of the eighth round, the AES key can be deduced using a two stage algorithm. The first step has a statistical expectation of reducing the possible key hypotheses to 232, and the second step to a mere 28.
978-3-642-21040-2_15_Chapter.pdf (133.86 Ko) Télécharger le fichier
hal-01573310 , version 1 (09-08-2017)
Paternité
Michael Tunstall, Debdeep Mukhopadhyay, Subidh Ali. Differential Fault Analysis of the Advanced Encryption Standard Using a Single Fault. 5th Workshop on Information Security Theory and Practices (WISTP), Jun 2011, Heraklion, Crete, Greece. pp.224-233, ⟨10.1007/978-3-642-21040-2_15⟩. ⟨hal-01573310⟩
207 Consultations
347 Téléchargements
