LAUDATIO-Repository - Archive ouverte HAL Access content directly
Poster Communications Year :
LAUDATIO-Repository
An open access to digital historical research data for historical linguistics enables a fruitful exchange of research sources and research methods. To achieve this goal the LAUDATIO-Repository provides a long-term open access to historical corpus linguistic data. By developing the LAUDATIO-Repository we also want to explore how to build repositories that are useful for a set of well defined communities but are also flexible enough to be used and extended to serve other communities not considered beforehand. Considering the user community's needs requires a clear understanding of the community's user scenarios and research.
DH2014SchweizPostersessionDemo.pdf (164.8 Ko) Télécharger le fichier
DH2014_Krause_et._al_Überarbeitung_2014-07-01.pdf (587.93 Ko) Télécharger le fichier
Dates and versions
hal-01574399 , version 1 (14-08-2017)
Attribution - CC BY 4.0
Identifiers
  • HAL Id : hal-01574399 , version 1
Cite
Thomas Krause, Anke Lüdeling, Carolin Odebrecht, Laurent Romary, Peter Schirmbacher, et al.. LAUDATIO-Repository: Accessing a heterogeneous field of linguistic corpora with the help of an open access repository. Digital Humanities 2014, Jul 2014, Lausanne, Switzerland. ⟨hal-01574399⟩
Collections
INRIA INRIA2
476 View
172 Download
Share
