A note on time-dependent additive functionals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications on Stochastic Analysis Année : 2017
This note develops shortly the theory of time-inhomogeneous additive functionals and is a useful support for the analysis of time-dependent Markov processes and related topics. It is a significant tool for the analysis of BSDEs in law. In particular we extend to a non-homogeneous setup some results concerning the quadratic variation and the angular bracket of Martin-gale Additive Functionals (in short MAF) associated to a homogeneous Markov processes.
AdditiveFunctionals.pdf (267.43 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01574964 , version 1 (17-08-2017)
Adrien Barrasso, Francesco Russo. A note on time-dependent additive functionals. Communications on Stochastic Analysis, 2017, 11 (3), pp.313-334. ⟨10.31390/cosa.11.3.04⟩. ⟨hal-01574964⟩
297 Consultations
308 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
