Two methods to measure granular gas temperature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Mechanics: Theory and Experiment Année : 2017
Grains are vibrated so as to achieve a granular gas, here regarded as an archetype for a dissipative Non Equilibrium Steady State (NESS). We report on two distinct and concordant experimental measures of the system effective temperature. To do so, a blade fastened to the shaft of a small DC-motor, immersed in the grains, behaves as a driven 1D Brownian rotator which is used as both actuator and sensor, simultaneously. On the one hand, the Gallavotti-Cohen Fluctuation Theorem (FT), which involves a measure of the asymmetry of the energy exchanges between the rotator and the NESS reservoir, provides a first effective temperature. On the other hand, the Fluctuation-Dissipation Theorem (FDT), which involves the relation between the spontaneous fluctuations and the response to a weak perturbation, defines a second, independent, effective temperature. Both methods, even though they are based on drastically different ideas, give nicely concordant results.
chastaing-rev.pdf (502.9 Ko) Télécharger le fichier
hal-01575240 , version 1 (18-08-2017)
J.-y Chastaing, J.-C Géminard, A Naert. Two methods to measure granular gas temperature. Journal of Statistical Mechanics: Theory and Experiment, 2017, 2017, pp.73212. ⟨10.1088/1742-5468/aa786b⟩. ⟨hal-01575240⟩
153 Consultations
199 Téléchargements
