Dynamically Distributed Network Control for Message Dissemination in ITS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose D2-ITS, a flexible and extensible framework to dynamically distribute network control to enable message dissemination in Intelligent Transport Systems (ITS). By decoupling the control- from the data plane, D2-ITS leverages network programmability to address ITS scalability, delay intolerance and decentralization. It uses a distributed control plane based on a hierarchy of controllers that can dynamically adjust to environment and network conditions in order to satisfy ITS application requirements. We demonstrate the benefits of D2-ITS through a proof-of-concept prototype using the ns-3 simulation platform. Results indicate lower message delivery latency with minimal additional overhead.
message-dissemination-software(3).pdf (544.75 Ko) Télécharger le fichier
hal-01579425 , version 1 (31-08-2017)
  • HAL Id : hal-01579425 , version 1
Anuj Kaul, Katia Obraczka, Mateus a S Santos, Christian E Rothenberg, Thierry Turletti. Dynamically Distributed Network Control for Message Dissemination in ITS. IEEE/ACM DS-RT 2017 - 21st International Symposium on Distributed Simulation and Real Time Applications, Oct 2017, Rome, Italy. ⟨hal-01579425⟩
276 Consultations
483 Téléchargements
