Automatic run-time versioning for BPEL processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Service Oriented Computing and Applications Année : 2017
We describe a middleware solution for automatic run-time process versioning in Business Process Execution Language (BPEL) and then analyse its impact in terms of scalability and performance. Business processes change in response to business needs, but the deployment of new versions to a BPEL engine must ensure that running instances are not disrupted and can conclude following their original workflows. Our solution is implemented as a standalone component that manages versioning transparently to the process editor, the orchestration engine, the web services used by the process, and the end-user. We have tested it for almost 1 year in the production environment of a telecommunications company, without significant overhead in terms of process invocation time.
SOCA-D-16-00017_R1 revised version submitted on 2017.12.14 before publication.pdf (993.92 Ko) Télécharger le fichier
hal-01581111 , version 1 (21-02-2018)
Paulo Melo, Paulo Rupino da Cunha, Catarina Ferreira da Silva, André Macedo. Automatic run-time versioning for BPEL processes. Service Oriented Computing and Applications, 2017, 11 (3), pp.315-327. ⟨10.1007/s11761-017-0211-3⟩. ⟨hal-01581111⟩
171 Consultations
182 Téléchargements
