Fault in the Future - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fault in the Future
Einar Broch Johnsen
  • Fonction : Auteur
  • PersonId : 1015680
In this paper we consider the problem of fault handling inside an object-oriented language with asynchronous method calls whose results are returned inside futures. We present an extension for those languages where futures are used to return fault notifications and to coordinate error recovery between the caller and callee. This can be exploited to ensure that invariants involving many objects are restored after faults.
978-3-642-21464-6_1_Chapter.pdf (395.42 Ko) Télécharger le fichier
hal-01582997 , version 1 (06-09-2017)
Paternité
Einar Broch Johnsen, Ivan Lanese, Gianluigi Zavattaro. Fault in the Future. 13th Conference on Coordination Models and Languages (COORDINATION), Jun 2011, Reykjavik, Iceland. pp.1-15, ⟨10.1007/978-3-642-21464-6_1⟩. ⟨hal-01582997⟩
297 Consultations
102 Téléchargements
