Empirical Evaluation of HTTP Adaptive Streaming under Vehicular Mobility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jun Yao
  • Fonction : Auteur
  • PersonId : 1015755
Salil S. Kanhere
  • Fonction : Auteur
  • PersonId : 1015756
Imran Hossain
  • Fonction : Auteur
  • PersonId : 1015757
Mahbub Hassan
  • Fonction : Auteur
  • PersonId : 1015758
Adaptive streaming is a promising technique for delivering a high-quality video streaming experience. In this technique, the streaming bit-rate is constantly adjusted in accordance to the variations in the underlying network bandwidth conditions. A popular instantiation of this approach is to extend traditional HTTP-based streaming. While several such implementations are widely available, it is unclear how they perform under a typical high-speed vehicular environment, wherein the wireless bandwidth varies significantly and rapidly. In this paper, we seek to provide some insights on this issue through empirical experiments driven by real-world wireless bandwidth traces collected from moving vehicles. Our results suggest that, with appropriate parameter configurations, HTTP adaptive streaming is an effective solution for delivering a high-quality smooth streaming experience even under high-speed vehicular mobility.
978-3-642-20757-0_8_Chapter.pdf (749.69 Ko) Télécharger le fichier
hal-01583412 , version 1 (07-09-2017)
Paternité
Jun Yao, Salil S. Kanhere, Imran Hossain, Mahbub Hassan. Empirical Evaluation of HTTP Adaptive Streaming under Vehicular Mobility. 10th IFIP Networking Conference (NETWORKING), May 2011, Valencia, Spain. pp.92-105, ⟨10.1007/978-3-642-20757-0_8⟩. ⟨hal-01583412⟩
72 Consultations
112 Téléchargements
