User to User QoE Routing System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently, wealthy network services such as Internet protocol television (IPTV) and Voice over IP (VoIP) are expected to become more pervasive over the Next Generation Network (NGN). In order to serve this purpose, the quality of these services should be evaluated subjectively by users. This is referred to as the quality of experience (QoE). The most important tendency of actual network services is maintaining the best QoE with network functions such as admission control, resource management, routing, traffic control, etc. Among of them, we focus here on routing mechanism. We propose in this paper a protocol integrating QoE measurement in routing paradigm to construct an adaptive and evolutionary system. Our approach is based on Reinforcement Learning concept. More concretely, we have used a least squares reinforcement learning technique called Least Squares Policy Iteration. Experimental results showed a significant performance gain over traditional routing protocols.
978-3-642-21560-5_30_Chapter.pdf (1.06 Mo) Télécharger le fichier
hal-01583650 , version 1 (07-09-2017)
Paternité
Hai Anh Tran, Abdelhamid Mellouk. User to User QoE Routing System. 9th Wired/Wireless Internet Communications (WWIC), Jun 2011, Vilanova i la Geltrú, Spain. pp.362-373, ⟨10.1007/978-3-642-21560-5_30⟩. ⟨hal-01583650⟩
43 Consultations
98 Téléchargements
