Abstract Categorial Grammars as a Model of the Syntax-Semantics Interface for TAG - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the ACG formalism and how to use it as a model of the syntax-semantics interface of Tree Adjoining Grammars.
tag+13-tutorial.handout.pdf (381.11 Ko) Télécharger le fichier
examples.zip (13.17 Ko) Télécharger le fichier
hal-01583962 , version 1 (08-09-2017)
hal-01583962 , version 2 (08-09-2017)
hal-01583962 , version 3 (20-09-2017)
  • HAL Id : hal-01583962 , version 3
Sylvain Pogodalla. Abstract Categorial Grammars as a Model of the Syntax-Semantics Interface for TAG. FSMNLP 2017 and TAG+13 conference, Sep 2017, Umeå, Sweden. ⟨hal-01583962v3⟩
405 Consultations
498 Téléchargements
