Magnetic field driven ambipolar quantum Hall effect in epitaxial graphene close to the charge neutrality point - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review B Année : 2017
We have investigated the disorder of epitaxial graphene close to the charge neutrality point (CNP) by various methods: (i) at room temperature, by analyzing the dependence of the resistivity on the Hall coefficient; (ii) by fitting the temperature dependence of the Hall coefficient down to liquid helium temperature; (iii) by fitting themagnetoresistances at low temperature. All methods converge to give a disorder amplitude of (20±10) meV. Because of this relatively low disorder, close to the CNP, at low temperature, the sample resistivity does not exhibit the standard value~h/4e^2 but diverges. Moreover, themagnetoresistance curves have a unique ambipolar behavior,which has been systematically observed for all studied samples.This is a signature of both asymmetry in the density of states and in-plane charge transfer. The microscopic origin of this behavior cannot be unambiguously determined. However, we propose a model in which the SiC substrate steps qualitatively explain the ambipolar behavior.
PhysRevB.96.075442.pdf (1 Mo) Télécharger le fichier
hal-01584484 , version 1 (12-06-2019)
Abir Nachawaty, M. Yang, Wilfried Desrat, Sébastien Nanot, B. Jabakhanji, et al.. Magnetic field driven ambipolar quantum Hall effect in epitaxial graphene close to the charge neutrality point. Physical Review B, 2017, 96 (7), pp.075442. ⟨10.1103/PhysRevB.96.075442⟩. ⟨hal-01584484⟩
304 Consultations
230 Téléchargements
