TR-Classifier and kNN Evaluation for Topic Identification tasks
This paper focuses on studying topic identification
for Arabic language by using two methods. The first method is
the well-known kNN (k Nearest Neighbors) which is used as
baseline. The second one is the TR-Classifier, mainly based on
computing triggers. The experiments show that TR-Classifier has
the advantage to give best performances compared to kNN, by
using much reduced sizes of Topic Vocabularies. TR-Classifier
performance is enhanced by increasing jointly the number of
triggers and the size of topic vocabularies. It should be noted that
topic vocabularies are used by the TR-Classifier. Whereas, a
general vocabulary is needed for kNN, and it is obtained by the
concatenation of those used by the TR-Classifier. In addition to
the standard measures Recall and Precision used for the
evaluation step, we have drawn ROC curves for some topics to
illustrate more clearly the difference in performance between the
two classifiers. The corpus used in our experiments is downloaded
from an online Arabic newspaper. Its size is about 10 millions
words, distributed over six selected topics, in this case: culture,
religion, economy, local news, international news and sports.
Informatique et langage [cs.CL]
