Public-Key Encrypted Bloom Filters with Applications to Supply Chain Integrity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bloom filters provide a space- and time-efficient mean to check the inclusion of an element in a set. In some applications it is beneficial, if the set represented by the Bloom filter is only revealed to authorized parties. Particularly, operations data in supply chain management can be very sensitive and Bloom filters can be applied to supply chain integrity validation. Despite the protection of the represented set, Bloom filter operations, such as the verification of set inclusion, need to be still feasible. In this paper we present privacy-preserving, publicly verifiable Bloom filters which offer both: privacy for the represented set and public Bloom filter operations. We give security proofs in the standard model.
978-3-642-22348-8_7_Chapter.pdf (307.6 Ko) Télécharger le fichier
hal-01586579 , version 1 (13-09-2017)
Paternité
Florian Kerschbaum. Public-Key Encrypted Bloom Filters with Applications to Supply Chain Integrity. 23th Data and Applications Security (DBSec), Jul 2011, Richmond, VA, United States. pp.60-75, ⟨10.1007/978-3-642-22348-8_7⟩. ⟨hal-01586579⟩
62 Consultations
182 Téléchargements
