Modeling Wireless Sensor Networks Using Finite-Source Retrial Queues with Unreliable Orbit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Patrick Wüchner
  • Fonction : Auteur
  • PersonId : 1016257
János Sztrik
  • Fonction : Auteur
  • PersonId : 1016258
Motivated by the need for performance models suitable for modeling and evaluation of wireless sensor networks, we introduce a retrial queueing system with a finite number of homogeneous sources, unreliable servers, orbital search, and unreliable orbit. All random variables involved in model construction are assumed to be independent and exponentially distributed. Providing a generalized stochastic Petri net model of the system, steady-state analysis of the underlying continuous-time Markov chain is performed and steady-state performance measures are computed by the help of the MOSEL-2 tool. The main novelty of this investigation is the introduction of an unreliable orbit and its application to wireless sensor networks. Numerical examples are derived to show the influence of sleep/awake time ratio, message dropping, and message blocking on the senor nodes’ performance.
978-3-642-25575-5_7_Chapter.pdf (582.17 Ko) Télécharger le fichier
hal-01586895 , version 1 (13-09-2017)
Paternité
Patrick Wüchner, János Sztrik, Hermann De Meer. Modeling Wireless Sensor Networks Using Finite-Source Retrial Queues with Unreliable Orbit. Performance Evaluation of Computer and Communication Systems (PERFORM), Oct 2010, Vienna, Austria. pp.73-86, ⟨10.1007/978-3-642-25575-5_7⟩. ⟨hal-01586895⟩
127 Consultations
125 Téléchargements
