Notions of Knowledge in Combinations of Theories Sharing Constructors
One of the most effective methods developed for the analysis of
security protocols is an approach based on equational reasoning and
unification. In this approach, it is important to have the capability
to reason about the knowledge of an intruder. Two important measures
of this knowledge, defined modulo equational theories, are
deducibility and static equivalence. We present new combination
techniques for the study of deducibility and static equivalence in
unions of equational theories sharing constructors. Thanks to these
techniques, we obtain new modularity results for the decidability of
deducibility and static equivalence. In turn, this should allow for the
analysis of protocols involving combined equational theories which
previous disjoint combination methods could not address due to their
non-disjoint axiomatization.
Logique en informatique [cs.LO]
