SDCurve.js: A JavaScript Library for Interactive Subdivision Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Charles Perin
We present SDCurve.js, a JavaScript library for creating interactive subdivision curves. Although subdivision curves are well-suited for use in interactive visualizations, the InfoVis community has used them sparingly. SDCurve.js is a lightweight, opensource, D3-compatible library that implements several common curve schemes, such as interpolating curves and B-Splines of any degree, in a subdivision framework that allows fast and easy curve interaction. We hope InfoVis researchers and designers will take advantage of it and contribute to its expansion.
2016_VIS_sdcurve.pdf (1.59 Mo) Télécharger le fichier
2016_VIS_sdcurve-poster.pdf (12.5 Mo) Télécharger le fichier
hal-01587940 , version 1 (14-09-2017)
  • HAL Id : hal-01587940 , version 1
Richard Pusch, Charles Perin, Sheelagh Carpendale. SDCurve.js: A JavaScript Library for Interactive Subdivision Curves. IEEE VIS 2016 Electronic Conference Proceedings, Oct 2016, Baltimore, United States. ⟨hal-01587940⟩
77 Consultations
616 Téléchargements
