Greyscale Image Vectorization from Geometric Digital Contour Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the field of digital geometry, numerous advances have been recently made to efficiently represent a simple polygonal shape; from dominant points of a curvature-based representation, a binary shape is efficiently represented even in presence of noise. In this article, we exploit recent results of such digital contour representations and propose an image vectorization algorithm allowing a geometric quality control. All the results presented in this paper can also be reproduced online.
Informatique
main.pdf (12.94 Mo) Télécharger le fichier
hal-01588695 , version 1 (16-09-2017)
Bertrand Kerautret, Phuc Ngo, Yukiko Kenmochi, Antoine Vacavant. Greyscale Image Vectorization from Geometric Digital Contour Representations. DGCI'17 - 20th International Conference on Discrete Geometry for Computer Imagery, Sep 2017, Vienna, Austria. pp.2379 - 331, ⟨10.1007/978-3-319-66272-5_26⟩. ⟨hal-01588695⟩
308 Consultations
231 Téléchargements
