A generalisation of Dillon's APN permutation with the best known differential and nonlinear properties for all fields of size $2^{4k+2}$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2017
The existence of Almost Perfect Nonlinear (APN) permutations operating on an even number of variables was a long-standing open problem, until an example with six variables was exhibited by Dillon et al. in 2009. However it is still unknown whether this example can be generalised to any even number of inputs. In a recent work, Perrin et al. described an infinite family of permutations, named butterflies, operating on (4k + 2) variables and with differential uniformity at most 4, which contains the Dillon APN permutation. In this paper, we generalise this family, and we completely solve the two open problems raised by Perrin et al. Indeed we prove that all functions in this larger family have the best known nonlinearity. We also show that this family does not contain any APN permutation besides the Dillon permutation, implying that all other functions have differential uniformity exactly four.
a_generalisation_of_dillons_apn_permutation_ieee_version.pdf (484.78 Ko) Télécharger le fichier
hal-01589131 , version 1 (18-09-2017)
Anne Canteaut, Sébastien Duval, Léo Perrin. A generalisation of Dillon's APN permutation with the best known differential and nonlinear properties for all fields of size $2^{4k+2}$. IEEE Transactions on Information Theory, 2017, 63 (11), pp.7575--7591. ⟨10.1109/TIT.2017.2676807⟩. ⟨hal-01589131⟩
157 Consultations
285 Téléchargements
