Motion Estimation under Location Uncertainty for Turbulent Fluid Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
In this paper, we propose a novel optical flow formulation for estimating two-dimensional velocity fields from an image sequence depicting the evolution of a passive scalar transported by a fluid flow. This motion estimator relies on a stochastic representation of the flow allowing to incorporate naturally a notion of uncertainty in the flow measurement. In this context, the Eulerian fluid flow velocity field is decomposed into two components: a large-scale motion field and a small-scale uncertainty component. We define the small-scale component as a random field. Subsequently , the data term of the optical flow formulation is based on a stochastic transport equation, derived from the formalism under location uncertainty proposed in Mémin (2014) and Resseguier et al. (2017a). In addition, a specific regulariza-tion term built from the assumption of constant kinetic energy involves the very same diffusion tensor as the one appearing in the data transport term. Opposite to the classical motion estimators, this enables us to devise an optical flow method dedicated to fluid flows in which the regularization parameter has now a clear physical interpretation and can be easily estimated. Experimental evaluations are presented on both synthetic and real world image sequences. Results and comparisons indicate very good performance of the proposed formulation for turbulent flow motion estimation.
Cai_20170918.pdf (2.51 Mo) Télécharger le fichier
hal-01589642 , version 1 (18-09-2017)
hal-01589642 , version 2 (06-11-2017)
  • HAL Id : hal-01589642 , version 1
Shengze Cai, Etienne Mémin, Pierre Dérian, Chao Xu. Motion Estimation under Location Uncertainty for Turbulent Fluid Flow. 2017. ⟨hal-01589642v1⟩
855 Consultations
306 Téléchargements
