A Risk-Based Evaluation of Group Access Control Approaches in a Healthcare Setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper focuses on access control approaches usable for information sharing through large screens where several individuals are present at the same time. Access control in this setting is quite different from traditional systems where a user logs on to the system. The paper outlines a number of possible approaches to access control, and evaluates them based on criteria derived from risk analyses of a planned coordination system for the perioperative hospital environment. It concludes that future work should focus on extending the location-based approach with situation awareness, and add support for using pop-ups or handheld devices for sharing of the most sensitive information.
978-3-642-23300-5_3_Chapter.pdf (201.41 Ko) Télécharger le fichier
hal-01590398 , version 1 (19-09-2017)
Paternité
Maria B. Line, Inger Anne Tøndel, Erlend Andreas Gjære. A Risk-Based Evaluation of Group Access Control Approaches in a Healthcare Setting. 1st Availability, Reliability and Security (CD-ARES), Aug 2011, Vienna, Austria. pp.26-37, ⟨10.1007/978-3-642-23300-5_3⟩. ⟨hal-01590398⟩
213 Consultations
59 Téléchargements
