Correlation model selection for interactive video communication
Interactive video communication has been recently proposed for multi-view videos. In this scheme, the server has to store the views as compact as possible, while being able to transmit them independently to the users, who are allowed to navigate interactively among the views, hence requesting a subset of them. To achieve this goal, the compression must be done using a model-based coding in which the correlation between the predicted view generated on the user side and the original view has to be modeled by a statistical distribution. In this paper we propose a framework for lossless fixed-length source coding to select a model among a candidate set of models that incurs the lowest extra rate cost to the system. Moreover, in cases where the depth image is available, we provide a method to estimate the correlation model.
