Numerical reconstruction of the first band(s) in an inverse Hill's problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2020
This paper concerns an inverse band structure problem for one dimensional periodic Schrödinger operators (Hill's operators). Our goal is to find a potential for the Hill's operator in order to reproduce as best as possible some given target bands, which may not be realisable. We recast the problem as an optimisation problem, and prove that this problem is well-posed when considering singular potentials (Borel measures). We then propose different algorithms to tackle the problem numerically.
inverse_problem_paper.pdf (561.54 Ko) Télécharger le fichier
hal-01591133 , version 1 (20-09-2017)
Athmane Bakhta, Virginie Ehrlacher, David Gontier. Numerical reconstruction of the first band(s) in an inverse Hill's problem. ESAIM: Control, Optimisation and Calculus of Variations, 2020, ⟨10.1051/cocv/2019031⟩. ⟨hal-01591133⟩
355 Consultations
126 Téléchargements
