Extracting an Etymological Database from Wiktionary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Electronic lexical resources almost never contain etymological information. The availability of such information, if properly formalised, could open up the possibility of developing automatic tools targeted towards historical and comparative linguistics, as well as significantly improving the automatic processing of ancient languages. We describe here the process we implemented for extracting etymological data from the etymological notices found in Wiktionary. We have produced a multilingual database of nearly one million lexemes and a database of more than half a million etymological relations between lexemes.
paper44.pdf (709.97 Ko) Télécharger le fichier
hal-01592061 , version 1 (22-09-2017)
  • HAL Id : hal-01592061 , version 1
Benoît Sagot. Extracting an Etymological Database from Wiktionary. Electronic Lexicography in the 21st century (eLex 2017), Sep 2017, Leiden, Netherlands. pp.716-728. ⟨hal-01592061⟩
Collections
INRIA INRIA2 ANR
536 Consultations
1098 Téléchargements
