A Trust-Based Defensive System Model for Cloud Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Qian Zhou
  • Fonction : Auteur
  • PersonId : 1017434
Jiong Yu
  • Fonction : Auteur
  • PersonId : 1017435
Feiran Yu
  • Fonction : Auteur
  • PersonId : 1017436
Because of the dynamic and open characteristics of the cloud computing, continuing malicious attacks happen frequently. Combining the idea of trusted cloud, a trust-based defensive system model for cloud computing has been constructed to guarantee the cloud security. Through real-timely monitoring, users’ behavior evidences have been obtained and standardized; a new method for users’ trust evaluation based on fuzzy AHP (Analytic Hierarchy Process, AHP) has been presented, it gradually determines the weights of behavior evidences, achieves quantitative assessment of behavioral trust; to provide great security defense for users, multiple detection engines have been used to conduct a comprehensive inspection of suspicious files and integrated decisions have been made. Experimental results show the system model can effectively eliminate the malicious behaviors from undesirable users, reduce users’ damages caused by virus and achieve a two-way defense for both cloud and client.
978-3-642-24403-2_12_Chapter.pdf (884.88 Ko) Télécharger le fichier
hal-01593026 , version 1 (25-09-2017)
Paternité
Qian Zhou, Jiong Yu, Feiran Yu. A Trust-Based Defensive System Model for Cloud Computing. 8th Network and Parallel Computing (NPC), Oct 2011, Changsha,, China. pp.146-159, ⟨10.1007/978-3-642-24403-2_12⟩. ⟨hal-01593026⟩
143 Consultations
74 Téléchargements
