H-Fuzzing: A New Heuristic Method for Fuzzing Data Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
How to efficiently reduce the fuzzing data scale while assuring high fuzzing veracity and vulnerability coverage is a pivotal issue in program fuzz test. This paper proposes a new heuristic method for fuzzing data generation named with H-Fuzzing. H-Fuzzing achieves a high program execution path coverage by retrieving the static information and dynamic property from the program. Our experiments evaluate H-Fuzzing, Java Path Finder (JPF) and random fuzzing method. The evaluation results demonstrate that H-Fuzzing can use fewer iterations and testing time to reach more test path coverage compared with the other two methods.
978-3-642-24403-2_3_Chapter.pdf (971.24 Ko) Télécharger le fichier
hal-01593032 , version 1 (25-09-2017)
Paternité
Jinjing Zhao, Yan Wen, Gang Zhao. H-Fuzzing: A New Heuristic Method for Fuzzing Data Generation. 8th Network and Parallel Computing (NPC), Oct 2011, Changsha,, China. pp.32-43, ⟨10.1007/978-3-642-24403-2_3⟩. ⟨hal-01593032⟩
147 Consultations
241 Téléchargements
