Virtualizing Stream Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stream processing systems have evolved into established solutions as standalone engines but they still lack flexibility in terms of large-scale deployment, integration, extensibility, and interoperability. In the last years, a substantial ecosystem of new applications has emerged that can potentially benefit from stream processing but introduces different requirements on how stream processing solutions can be integrated, deployed, extended, and federated. To address these needs, we present an exoengine architecture and the associated ExoP platform. Together, they provide the means for encapsulating components of stream processing systems as well as automating the data exchange between components and their distributed deployment. The proposed solution can be used, e.g., to connect heterogeneous streaming engines, replace operators at runtime, and migrate operators across machines with a negligible overhead.
978-3-642-25821-3_14_Chapter.pdf (370.8 Ko) Télécharger le fichier
hal-01597774 , version 1 (28-09-2017)
Paternité
Michael Duller, Jan S. Rellermeyer, Gustavo Alonso, Nesime Tatbul. Virtualizing Stream Processing. 12th International Middleware Conference (MIDDLEWARE), Dec 2011, Lisbon, Portugal. pp.269-288, ⟨10.1007/978-3-642-25821-3_14⟩. ⟨hal-01597774⟩
394 Consultations
97 Téléchargements
