Diving into the Data Ocean - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dieter Meiller
  • Fonction : Auteur
  • PersonId : 1020120
In this paper we present the concept for a novel user interface that simplifies the management of data and the search of information strongly: Instead of a reactive system, a proactive system is suggested. As a substitute of the desktop metaphor we propose to model data as active creatures that move inside the ecosystem computer: a Data Ocean. The concept can be used for different applications to manage objects with varying properties.
346948_1_En_39_Chapter.pdf (1.08 Mo) Télécharger le fichier
hal-01610832 , version 1 (05-10-2017)
Paternité
Dieter Meiller. Diving into the Data Ocean. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.465-468, ⟨10.1007/978-3-319-22723-8_39⟩. ⟨hal-01610832⟩
49 Consultations
60 Téléchargements
