Actuated Shear: Enabling Haptic Feedback on Rich Touch Interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bernhard Maurer
  • Fonction : Auteur
  • PersonId : 1018423
Roland Buchner
  • Fonction : Auteur
  • PersonId : 1017051
Martin Murer
  • Fonction : Auteur
  • PersonId : 1011765
Manfred Tscheligi
  • Fonction : Auteur
  • PersonId : 989546
We present an approach of a shear force based touch interface that provides a way of actively changing the possible shear-based input (force tangential to a screens surface) by physically locking the corresponding axis of the device. This approach of actuated shear aims at using shear not only as input, but to create a new form of output modality that changes the input affordance of the device itself. It enables a new channel of incorporating physical information and constraints into touch-based interaction (i.e., by changing the input affordance of the device and using shear as a feedback mechanism). With this actuated shear approach, we create a coupling between the digital context created via touch and the actual physical input affordance of the device. Based on the implementation of a prototype, we discuss the design space of actively changing the input affordance of a shear-based touch device, sketch interaction ideas as well as future application scenarios and domains.
346948_1_En_11_Chapter.pdf (323.77 Ko) Télécharger le fichier
hal-01610834 , version 1 (05-10-2017)
Paternité
Bernhard Maurer, Roland Buchner, Martin Murer, Manfred Tscheligi. Actuated Shear: Enabling Haptic Feedback on Rich Touch Interfaces. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.140-147, ⟨10.1007/978-3-319-22723-8_11⟩. ⟨hal-01610834⟩
132 Consultations
97 Téléchargements
