Tangible Voting: A Technique for Interacting with Group Choices on a Tangible Tabletop - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The tangible tabletop has been exploited in many different application domains as one of the most popular setups of Tangible User Interfaces. Proposed interaction techniques are based on, for instance, direct manipulation, dual hand input, or physical actuation. This paper reports on the design and implementation of a new interaction technique to support multiple users in their specifying and manipulating individual choices on a tangible tabletop. The proposed tangible widget consists of both a physical enclosing with several separated zones, and a number of tokens that can be distributed in these zones to specify the individual choices of the group. We present the rationale used in design, the technical implementation, and report on the use of the interaction technique during workshops with children.
346948_1_En_7_Chapter.pdf (349.04 Ko) Télécharger le fichier
hal-01610847 , version 1 (05-10-2017)
Paternité
Valérie Maquil, Eric Tobias, Thibaud Latour. Tangible Voting: A Technique for Interacting with Group Choices on a Tangible Tabletop. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.79-86, ⟨10.1007/978-3-319-22723-8_7⟩. ⟨hal-01610847⟩
49 Consultations
86 Téléchargements
