Research and Design of Wireless Sensor Middleware Based on STM32 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jiye Zheng
  • Fonction : Auteur
  • PersonId : 972306
Fengyun Wang
  • Fonction : Auteur
  • PersonId : 972081
Lei Wang
  • Fonction : Auteur
  • PersonId : 1020456
In order to make agricultural production become more convenient, also meet the requirement of the modern intelligent agriculture to make control equipment integrated and miniaturization, the paper designed a wireless sensor middleware based on STM32. This wireless gateway receives control command from the control software of agricultural IOT application which installed in the tablet computer through the WiFi/USART module, after the data processing and protocol conversion, then send the control signal to the wireless sensor network through the USART port. At the same time, if a particular model of agricultural sensor changes state, it also can timely feedback to the tablet computer to display through the gateway. This plan solved the problem of real-time monitoring of agricultural information and realized remote control. The experimental results show that, the wireless sensor middleware has the characteristics of light and handy, high control precision, data large quantity and high speed. It’s very appropriate for intelligent agricultural system application.
434298_1_En_60_Chapter.pdf (405.3 Ko) Télécharger le fichier
hal-01614206 , version 1 (10-10-2017)
Paternité
Jiye Zheng, Fengyun Wang, Lei Wang. Research and Design of Wireless Sensor Middleware Based on STM32. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.579-585, ⟨10.1007/978-3-319-48354-2_60⟩. ⟨hal-01614206⟩
136 Consultations
180 Téléchargements
