The Supply Chain Improvement Through Primary Collaboration. An Action Research Experience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jesús García-Arca
  • Fonction : Auteur
  • PersonId : 1020562
J. Carlos Prado-Prado
  • Fonction : Auteur
  • PersonId : 1020563
Collaboration among companies arises as one of the key factors that could increase the supply chain performance. This collaboration is more difficult if these companies have the same status in the supply chain and they are small and medium sized companies. In this context, the aim of this paper is to propose and validate a methodology for achieving confidence for primary collaboration throughout the food supply chain and as a previous step for developing “collaboration networks”. In the paper, the authors have adopted the “Action research” approach, leading and coordinating a Collaboration Project among 10 food companies and 5 agricultural cooperatives.
430868_1_En_53_Chapter.pdf (311.88 Ko) Télécharger le fichier
hal-01614605 , version 1 (11-10-2017)
Paternité
Jesús García-Arca, J. Carlos Prado-Prado, A. Trinidad González-Portela. The Supply Chain Improvement Through Primary Collaboration. An Action Research Experience. 17th Working Conference on Virtual Enterprises (PRO-VE), Oct 2016, Porto, Portugal. pp.618-625, ⟨10.1007/978-3-319-45390-3_53⟩. ⟨hal-01614605⟩
213 Consultations
98 Téléchargements
