Noisy Control About Discrete Liner Consensus Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zhongzhi Shi
  • Fonction : Auteur
  • PersonId : 990754
Yuehao Pan
  • Fonction : Auteur
  • PersonId : 1020696
In recent years, more and more researchers in the control community have focused their attention on distributed coordination due to its broad applications in many fields, the consensus problem is well recognized as a fundamental problem in the cooperation control of multi-agent systems. In this paper, we discuss the noise problem of the discrete linear consensus protocol (DLCP) and point out that noise of DLCP is uncontrollable. A protocol using noise suppression function (NS-DLCP) to control the noise is put forward, the theorem about the reasonable range of the noise suppression function is vigorously proved, and sufficient conditions for noise controllable of NS-DLCP are further presented.
433802_1_En_24_Chapter.pdf (496.32 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01615001 , version 1 (11-10-2017)
Quansheng Dou, Zhongzhi Shi, Yuehao Pan. Noisy Control About Discrete Liner Consensus Protocol. 9th International Conference on Intelligent Information Processing (IIP), Nov 2016, Melbourne, VIC, Australia. pp.235-244, ⟨10.1007/978-3-319-48390-0_24⟩. ⟨hal-01615001⟩
55 Consultations
103 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
