From English to RDF - A Meta-Modelling Approach for Predictive Maintenance Knowledge Base Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ever growing complexity of the information domains that are relevant for product life cycle management is pushing researchers to invest efforts into creating an abstract modelling techniques in order to structure the available knowledge. Ontology showed to be a convenient method for build such structures and number of domain specific ontologies has been developed in recent years. In this paper, we propose a meta-modelling approach that provides a guided, step-by-step solution for ontology design. Contribution is tested through an example of ontology for predictive maintenance.
434863_1_En_26_Chapter.pdf (5.68 Mo) Télécharger le fichier
hal-01615733 , version 1 (12-10-2017)
Paternité
Ana Milicic, Dimitris Kiritsis, Nesat Efendioglu. From English to RDF - A Meta-Modelling Approach for Predictive Maintenance Knowledge Base Design. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.214-224, ⟨10.1007/978-3-319-51133-7_26⟩. ⟨hal-01615733⟩
133 Consultations
87 Téléchargements
