Developing Supplier Strategies for ETO Companies: A Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mikhail Shlopak
  • Fonction : Auteur
  • PersonId : 997805
Espen Rød
  • Fonction : Auteur
  • PersonId : 997803
Oddmund Oterhals
  • Fonction : Auteur
  • PersonId : 997806
The purpose of this paper is to present results of applying the Kraljic purchasing portfolio model at three Norwegian engineer-to-order (ETO) companies. The case companies operate in different markets, deliver products of different levels of complexity, and apply different organizational strategies, and differ in several other ways. The paper discusses the ways in which the case companies can develop their supplier strategies based on the executed Kraljic analysis, while emphasizing the importance of taking the companies’ distinctive features into consideration.
434863_1_En_107_Chapter.pdf (10.59 Mo) Télécharger le fichier
hal-01615761 , version 1 (12-10-2017)
Paternité
Mikhail Shlopak, Espen Rød, Oddmund Oterhals. Developing Supplier Strategies for ETO Companies: A Case Study. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2016, Iguassu Falls, Brazil. pp.911-918, ⟨10.1007/978-3-319-51133-7_107⟩. ⟨hal-01615761⟩
65 Consultations
301 Téléchargements
