Digital History: Towards New Methodologies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The field of Digital Humanities is changing the way historians do their research. Historians use tools to query larger data sets and they apply a different methodology to tackle certain research questions. In this paper we will discuss two propositions on the necessity of adapting to and taking advantage of the technological changes: (1) Digital Humanities tools are not the enemy of the historian, but they need to be used in a proper way. This requires historians to make ‘tool criticism’ part of their methodological toolkit; (2) Digital Humanities tools allow for a more data-driven and bottom-up approach to historical research. This eliminates some of the historian’s preconceptions that are inevitably part of more traditional historical research.
431566_1_En_3_Chapter.pdf (157.36 Ko) Télécharger le fichier
hal-01616305 , version 1 (13-10-2017)
Paternité
Serge Ter Braake, Antske Fokkens, Niels Ockeloen, Chantal Van Son. Digital History: Towards New Methodologies. 2nd International Workshop on Computational History and Data-Driven Humanities (CHDDH), May 2016, Dublin, Ireland. pp.23-32, ⟨10.1007/978-3-319-46224-0_3⟩. ⟨hal-01616305⟩
131 Consultations
274 Téléchargements
