24/7 place recognition by view synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2017
We address the problem of large-scale visual place recognition for situations where the scene undergoes a major change in appearance, for example, due to illumination (day/night), change of seasons, aging, or structural modifications over time such as buildings being built or destroyed. Such situations represent a major challenge for current large-scale place recognition methods. This work has the following three principal contributions. First, we demonstrate that matching across large changes in the scene appearance becomes much easier when both the query image and the database image depict the scene from approximately the same viewpoint. Second, based on this observation, we develop a new place recognition approach that combines (i) an efficient synthesis of novel views with (ii) a compact indexable image representation. Third, we introduce a new challenging dataset of 1,125 camera-phone query images of Tokyo that contain major changes in illumination (day, sunset, night) as well as structural changes in the scene. We demonstrate that the proposed approach significantly outperforms other large-scale place recognition techniques on this challenging data.
Torii-PAMI-2016-cameraready.pdf (3.67 Mo) Télécharger le fichier
hal-01616660 , version 1 (13-10-2017)
Akihiko Torii, Relja Arandjelovic, Josef Sivic, Masatoshi Okutomi, Tomas Pajdla. 24/7 place recognition by view synthesis. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2017, pp.14. ⟨10.1109/TPAMI.2017.2667665⟩. ⟨hal-01616660⟩
370 Consultations
1450 Téléchargements
