Journal articles
Minimal convex extensions and finite difference discretization of the quadratic Monge-Kantorovich problem
Abstract : We present an adaptation of the MA-LBR scheme to the Monge-Ampère equation with second boundary value condition, provided the target is a convex set. This yields a fast adaptive method to numerically solve the Optimal Transport problem between two absolutely continuous measures, the second of which has convex support. The proposed numerical method actually captures a specific Brenier solution which is minimal in some sense. We prove the convergence of the method as the grid stepsize vanishes and we show with numerical experiments that it is able to reproduce subtle properties of the Optimal Transport problem.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01616842
Contributor : Vincent Duval Connect in order to contact the contributor
Submitted on : Tuesday, July 17, 2018 - 4:04:24 PM
Last modification on : Wednesday, November 17, 2021 - 12:33:15 PM
Long-term archiving on: : Monday, October 1, 2018 - 3:49:05 AM
MABV2final.pdf
Identifiers
Collections
Citation
Jean-David Benamou, Vincent Duval. Minimal convex extensions and finite difference discretization of the quadratic Monge-Kantorovich problem. European Journal of Applied Mathematics, Cambridge University Press (CUP), In press, ⟨10.1017/S0956792518000451⟩. ⟨hal-01616842v3⟩
Share
Metrics
Record views
475
Files downloads
636
