Critical Realism and Actor-Network Theory/Deleuzian Thinking: A Critical Comparison in the Area of Information Systems, Technology and Organizational Studies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chris Mclean
  • Fonction : Auteur
  • PersonId : 1021158
Jeremy Aroles
Much debate has encircled studies of information systems (IS), technology and organizations with regards to ideas of process, stability and change, performance and materiality. This encapsulates different ways of viewing dualities (e.g. subjective/objective, social/technical, local/global, macro/micro, structure/agency, reality/construction, being/becoming, etc.) as well as alternative ontological and epistemological commitments underlying particular approaches and research perspectives. This paper seeks to explore two specific approaches by focusing on a comparison of critical realism (CR) and actor-network theory (ANT)/Deleuze-inspired forms of inquiry. In particular, we focus on the notion of morphogenesis in order to explore in greater detail how this concept conjures up rather different images in relation to approaches centred around CR and ANT/Deleuze.
434865_1_En_4_Chapter.pdf (262.75 Ko) Télécharger le fichier
hal-01619201 , version 1 (19-10-2017)
Paternité
Chris Mclean, Jeremy Aroles. Critical Realism and Actor-Network Theory/Deleuzian Thinking: A Critical Comparison in the Area of Information Systems, Technology and Organizational Studies. Working Conference on Information Systems and Organizations (ISO), Dec 2016, Dublin, Ireland. pp.58-72, ⟨10.1007/978-3-319-49733-4_4⟩. ⟨hal-01619201⟩
193 Consultations
900 Téléchargements
