Automated Log Audits for Privacy Compliance Validation: A Literature Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
Jenni Reuben
  • Fonction : Auteur
  • PersonId : 1021208
Leonardo A. Martucci
  • Fonction : Auteur
  • PersonId : 997979
Simone Fischer-Hübner
  • Fonction : Auteur
  • PersonId : 997980
Log audits are the technical means to retrospectively reconstruct and analyze system activities for determining if the system is executed in accordance with the rules. This approach to compliance is referred to as compliance by detection. In the case of privacy adherence validation (or) privacy audits, the rules for compliance are less well defined and more contextual than in the case of traditional security audit. The aim of the paper is to understand the aims, techniques and challenges for realizing privacy compliance by detection. Using systematic literature review as the research tool we described the state-of-art privacy auditing approaches through taxonomies. We present two taxonomies, (i) classified in terms of auditing techniques and (ii) classified in terms of audit objectives. Following the observation gained from the state-of-the art we discuss challenges and suggest guidelines for utilizing log-based automated privacy audits.
428330_1_En_21_Chapter.pdf (201.76 Ko) Télécharger le fichier
hal-01619730 , version 1 (19-10-2017)
Paternité
Jenni Reuben, Leonardo A. Martucci, Simone Fischer-Hübner. Automated Log Audits for Privacy Compliance Validation: A Literature Survey. David Aspinall; Jan Camenisch; Marit Hansen; Simone Fischer-Hübner; Charles Raab. Privacy and Identity Management. Time for a Revolution? : 10th IFIP WG 9.2, 9.5, 9.6/11.7, 11.4, 11.6/SIG 9.2.2 International Summer School, Edinburgh, UK, August 16-21, 2015, Revised Selected Papers, AICT-476, Springer International Publishing, pp.312-326, 2016, IFIP Advances in Information and Communication Technology, 978-3-319-41762-2. ⟨10.1007/978-3-319-41763-9_21⟩. ⟨hal-01619730⟩
81 Consultations
177 Téléchargements
