Ontology-Based Obfuscation and Anonymisation for Privacy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
Healthcare Information Systems typically fall into the group of systems in which the need of data sharing conflicts with the privacy. A myriad of these systems have to, however, constantly communicate among each other. One of the ways to address the dilemma between data sharing and privacy is to use data obfuscation by lowering data accuracy to guarantee patient’s privacy while retaining its usefulness. Even though many obfuscation methods are able to handle numerical values, the obfuscation of non-numerical values (e.g., textual information) is not as trivial, yet extremely important to preserve data utility along the process. In this paper, we preliminary investigate how to exploit ontologies to create obfuscation mechanism for releasing personal and electronic health records (PHR and EHR) to selected audiences with different degrees of obfuscation. Data minimisation and access control should be supported to enforce different actors, e.g., doctors, nurses and managers, will get access to no more information than needed for their tasks. Besides that, ontology-based obfuscation can also be used for the particular case of data anonymisation. In such case, the obfuscation has to comply with a specific criteria to provide anonymity, so that the data set could be safely released. This research contributes to: state the problems in the area; review related privacy and data protection legal requirements; discuss ontology-based obfuscation and anonymisation methods; and define relevant healthcare use cases. As a result, we present the early concept of our Ontology-based Data Sharing Service (O-DSS) that enforces patient’s privacy by means of obfuscation and anonymisation functions.
428330_1_En_23_Chapter.pdf (1.34 Mo) Télécharger le fichier
hal-01619736 , version 1 (19-10-2017)
Paternité
Leonardo H. Iwaya, Fausto Giunchiglia, Leonardo A. Martucci, Alethia Hume, Simone Fischer-Hübner, et al.. Ontology-Based Obfuscation and Anonymisation for Privacy. David Aspinall; Jan Camenisch; Marit Hansen; Simone Fischer-Hübner; Charles Raab. Privacy and Identity Management. Time for a Revolution? : 10th IFIP WG 9.2, 9.5, 9.6/11.7, 11.4, 11.6/SIG 9.2.2 International Summer School, Edinburgh, UK, August 16-21, 2015, Revised Selected Papers, AICT-476, Springer International Publishing, pp.343-358, 2016, IFIP Advances in Information and Communication Technology, 978-3-319-41762-2. ⟨10.1007/978-3-319-41763-9_23⟩. ⟨hal-01619736⟩
69 Consultations
150 Téléchargements
