Abstract : In the present work we consider a frictional contact model with normal compliance. Firstly, we discuss the weak solvability of the model by means of two variational approaches. In a first approach the weak solution is a solution of a quasivariational inequality. In a second approach the weak solution is a solution of a mixed variational problem with solution-dependent set of Lagrange multipliers. Nextly, the paper focuses on the boundary optimal control of the model. Existence results, an optimality condition and some convergence results are presented.
https://hal.inria.fr/hal-01626881
Contributor : Hal Ifip <>
Submitted on : Tuesday, October 31, 2017 - 2:39:56 PM Last modification on : Tuesday, October 31, 2017 - 2:45:08 PM Long-term archiving on: : Thursday, February 1, 2018 - 1:35:41 PM
Andaluzia Matei. On the Weak Solvability and the Optimal Control of a Frictional Contact Problem with Normal Compliance. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.370-379, ⟨10.1007/978-3-319-55795-3_35⟩. ⟨hal-01626881⟩
