Dynamic Programming Approach for Discrete-Valued Time Discrete Optimal Control Problems with Dwell Time Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The article discusses a numerical approach to solve optimal control problems in discrete time that involve continuous and discrete controls. Special attention is drawn to the modeling and treatment of dwell time constraints. For the solution of the optimal control problem in discrete time, a dynamic programming approach is employed. A numerical example is included that illustrates the impact of dwell time constraints in mixed integer optimal control.
447583_1_En_14_Chapter.pdf (290.8 Ko) Télécharger le fichier
hal-01626891 , version 1 (31-10-2017)
Paternité
Michael Burger, Matthias Gerdts, Simone Göttlich, Michael Herty. Dynamic Programming Approach for Discrete-Valued Time Discrete Optimal Control Problems with Dwell Time Constraints. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.159-168, ⟨10.1007/978-3-319-55795-3_14⟩. ⟨hal-01626891⟩
100 Consultations
284 Téléchargements
