Abstract : The paper discusses a class of bilevel optimal control problems with optimal control problems at both levels. The problem will be transformed to an equivalent single level problem using the value function of the lower level optimal control problem. Although the computation of the value function is difficult in general, we present a pursuit-evasion Stackelberg game for which the value function of the lower level problem can be derived even analytically. A direct discretization method is then used to solve the transformed single level optimal control problem together with some smoothing of the value function.
Lorena Bociu; Jean-Antoine Désidéri; Abderrahmane Habbal. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. Springer International Publishing, IFIP Advances in Information and Communication Technology, AICT-494, pp.410-419, 2016, System Modeling and Optimization. 〈10.1007/978-3-319-55795-3_39〉
https://hal.inria.fr/hal-01626921
Contributeur : Hal Ifip
Soumis le : mardi 31 octobre 2017 - 14:41:39
Dernière modification le : mardi 31 octobre 2017 - 14:44:52
Document(s) archivé(s) le : jeudi 1 février 2018 - 13:00:40
Konstantin Palagachev, Matthias Gerdts. Exploitation of the Value Function in a Bilevel Optimal Control Problem. Lorena Bociu; Jean-Antoine Désidéri; Abderrahmane Habbal. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. Springer International Publishing, IFIP Advances in Information and Communication Technology, AICT-494, pp.410-419, 2016, System Modeling and Optimization. 〈10.1007/978-3-319-55795-3_39〉. 〈hal-01626921〉
