Unified Polyhedral Modeling of Temporal and Spatial Locality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Despite decades of work in this area, the construction of effective loop nest optimizers and parallelizers continues to be challenging due to the increasing diversity of both loop-intensive application workloads and complex memory/computation hierarchies in modern processors. The lack of a systematic approach to optimizing locality and parallelism, with a well-founded data locality model, is a major obstacle to the design of optimizing compilers coping with the variety of software and hardware. Acknowledging the conflicting demands on loop nest optimization, we propose a new unified algorithm for optimizing parallelism and locality in loop nests, that is capable of modeling temporal and spatial effects of multiprocessors and accelerators with deep memory hierarchies and multiple levels of parallelism. It orchestrates a collection of parameterizable optimization problems for locality and parallelism objectives over a polyhedral space of semantics-preserving transformations. The overall problem is not convex and is only constrained by semantics preservation. We discuss the rationale for this unified algorithm, and validate it on a collection of representative computational kernels/benchmarks.
Malgré les décennies de travail dans ce domaine, la construction de compilateurs capables de paraléliser et optimiser les nids de boucle reste un problème difficile, dans le contexte d’une augmentation de la diversité des applications calculatoires et de la complexité de la hiérarchie de calcul et de stockage des processeurs modernes. L’absence d’une méthode systématique pour optimiser la localité et le parallélisme, fondée sur un modèle de localité des données pertinent, constitue un obstacle majeur pour prendre en charge la variété des besoins en optimisation de boucles issus du logiciel et du matériel. Dans ce contexte, nous proposons un nouvel algorithme unifié pour l’optimisation du parallélisme et de la localité dans les nids de boucles, capable de modéliser les effets temporels et spatiaux des multiprocesseurs et accélérateurs comportant des hiérarchies profondes de parallélisme et de mémoire. Cet algorithme coordonne la résolution d’une collection de problèmes d’optimisation paramètrés, portant sur des objectifs de localité ou et de parallélisme, dans un espace polyédrique de transformations préservant la sémantique du programme. La conception de cet algorithme fait l’objet d’une discussion systématique, ainsi que d’une validation expérimentale sur des noyaux calculatoires et benchmarks représentatifs.
RR-9110.pdf (4.75 Mo) Télécharger le fichier
RR-9110.tar.gz (10.26 Mo) Télécharger le fichier
hal-01628798 , version 1 (06-11-2017)
  • HAL Id : hal-01628798 , version 1
Oleksandr Zinenko, Sven Verdoolaege, Chandan Reddy, Jun Shirako, Tobias Grosser, et al.. Unified Polyhedral Modeling of Temporal and Spatial Locality. [Research Report] RR-9110, Inria Paris. 2017, pp.41. ⟨hal-01628798⟩
437 Consultations
445 Téléchargements
