Implicit Bias in Predictive Data Profiling Within Recruitments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
Anders Persson
  • Fonction : Auteur
  • PersonId : 1022155
Recruiters today are often using some kind of tool with data mining and profiling, as an initial screening for successful candidates. Their objective is often to become more objective and get away from human limitation, such as implicit biases versus underprivileged groups of people. In this explorative analysis there have been three potential problems identified, regarding the practice of using these predictive computer tools for hiring. First, that they might miss the best candidates, as the employed algorithms are tuned with limited and outdated data. Second, is the risk of directly or indirectly discriminate candidates, or, third, failure to give equal opportunities for all individuals. The problems are not new to us, and from this theoretical analysis and from other similar work; it seems that algorithms and predictive data mining tools have similar kinds of implicit biases as humans. Our human limitations, then, does not seem to be limited to us humans.
447020_1_En_15_Chapter.pdf (630.17 Ko) Télécharger le fichier
hal-01629166 , version 1 (06-11-2017)
Paternité
Anders Persson. Implicit Bias in Predictive Data Profiling Within Recruitments. Anja Lehmann; Diane Whitehouse; Simone Fischer-Hübner; Lothar Fritsch; Charles Raab. Privacy and Identity Management. Facing up to Next Steps : 11th IFIP WG 9.2, 9.5, 9.6/11.7, 11.4, 11.6/SIG 9.2.2 International Summer School, Karlstad, Sweden, August 21-26, 2016, Revised Selected Papers, AICT-498, Springer International Publishing, pp.212-230, 2016, IFIP Advances in Information and Communication Technology, 978-3-319-55782-3. ⟨10.1007/978-3-319-55783-0_15⟩. ⟨hal-01629166⟩
119 Consultations
339 Téléchargements
